dreco Posted June 25, 2005 Share Posted June 25, 2005 I've been reading into this swap and like it the more I read about it... Ive read that this swap can be done with the motor mounts of a Z31?? anyone know the part number for that (didn't see it in the threads)?? also I've read about the tranny mounting fabrications, but I've only read about the 240Z with the later type mounting brakets. ( my transmission braket has 2 bolts that bolt straight up, not the braket that slides in between the flanges... anyone have any pictures of this fabrication?? or can you link me to where they are in this forum?? I think ultimately I'll have a shop do the labor (just becuase I'm so unfamiliar with this engine), but I figure the more I learn, the cheaper it will be for me in the long run.. Quote Link to comment Share on other sites More sharing options...
Zhadman Posted June 25, 2005 Share Posted June 25, 2005 http://forums.hybridz.org/showthread.php?p=545169#post545169 Jump up to post #76 and then down to #82 11232-41L00 11233-41L00 Part numbers for the mounts. There's additional info in that post relating to oilpans, pickups... etc. Quote Link to comment Share on other sites More sharing options...
dreco Posted June 25, 2005 Author Share Posted June 25, 2005 http://forums.hybridz.org/showthread.php?p=545169#post545169 Jump up to post #76 and then down to #82 11232-41L00 11233-41L00 Part numbers for the mounts. There's additional info in that post relating to oilpans' date=' pickups... etc.[/quote'] great!! thanks. Quote Link to comment Share on other sites More sharing options...
240Z_Master Posted June 30, 2005 Share Posted June 30, 2005 I've read about the tranny mounting fabrications, but I've only read about the 240Z with the later type mounting brakets. ( my transmission braket has 2 bolts that bolt straight up, not the braket that slides in between the flanges... .. I have this dillemma too. I think one way was to shave down the ears and weld on a plate. I can't remember who it was, but one member did that. Theres been a couple ways that have been done on this site. I have the photos saved if you want to leave your email so I can send you photos. Quote Link to comment Share on other sites More sharing options...
