cyrus Posted July 6, 2005 Share Posted July 6, 2005 First off it is a 2.94. Second I believe it is a R230. Third it has not sensors on any in or output flanges. thirdly It seems to spin relatively freely. Is it a Viscous? No stick and I would rather not take the back off. I may get pics soon. Quote Link to comment Share on other sites More sharing options...
BlackBeaut Posted July 6, 2005 Share Posted July 6, 2005 First off it is a 2.94. Second I believe it is a R230. Third it has not sensors on any in or output flanges. thirdly It seems to spin relatively freely. Is it a Viscous? No stick and I would rather not take the back off. I may get pics soon. Do the outputs rotate the same way when you turn the input? Pretty high chance it will be a viscous diff if it's LSD as they're cheap and cheerful. How many bolts are there on the top row holding the back cover on? If just 2 then it's most likely a R200, if it's 3 then you're probably looking at a R230 and if so you HAVE to pull it apart for the good of the community Get those pics taken! Cheers, Rob Quote Link to comment Share on other sites More sharing options...
mas28O Posted July 6, 2005 Share Posted July 6, 2005 cyrus why do you want the 2.94 gears? It would be nice for a v8 but you have a 6cly. Mike Quote Link to comment Share on other sites More sharing options...
Guest JAMIE T Posted July 7, 2005 Share Posted July 7, 2005 This thread is useless without pics!!! POST PICS! Quote Link to comment Share on other sites More sharing options...
cyrus Posted July 7, 2005 Author Share Posted July 7, 2005 Well I found out that Nissan idea of limited slip is to have the brakes selectively applied to the slipping wheel. That leaves me with problem. I have a perfect 2005 R230 with only 150 miles on it and no LSD. Can I add one. I will get pics shortly. Need some help. As far as the 2.94 rear end gear it would be perfect for my 6 because Getrag V160 have a ~3.9:1 1st gear ratio. Even Supras run 3.08 adn 3.24 rear end gears. Quote Link to comment Share on other sites More sharing options...
Scottie-GNZ Posted July 7, 2005 Share Posted July 7, 2005 This thread is useless without pics!!! Said another way, Quote Link to comment Share on other sites More sharing options...
cyrus Posted July 8, 2005 Author Share Posted July 8, 2005 Now that I took one for the team, how can I put a posi in this? Quote Link to comment Share on other sites More sharing options...
CruxGNZ Posted July 8, 2005 Share Posted July 8, 2005 Couldn't you swap the viscous carrier (300ZX, Q45) into your differential? I would LOVE that gearing for my Z! How much cabbage did that cost ya? !M! Quote Link to comment Share on other sites More sharing options...
Guest Battle Pope Posted July 8, 2005 Share Posted July 8, 2005 Yeah, you should be able to just pop in the viscous from a 300ZX TT R230... Quote Link to comment Share on other sites More sharing options...
Guest JAMIE T Posted July 8, 2005 Share Posted July 8, 2005 Sure looks like an R230 to me. The carrier is tiny, LOL. The viscous carrier is alot bigger. Cyrus, I really appreciate you buying one of those and posting pics and such. It may be the case that Nissan offers more than one ratio for the Armada. I might go to the stealership and ask about it. I've got a 300ZXTT R230 that is going behind my RB26. Quote Link to comment Share on other sites More sharing options...
cyrus Posted July 8, 2005 Author Share Posted July 8, 2005 So here is my question, what do I have to do to put the 300ZX TT viscous carrier in here? Quote Link to comment Share on other sites More sharing options...
Montoya Posted July 11, 2005 Share Posted July 11, 2005 Before you go trying to find a viscous LSD from a used 300ZXTT diff, how much power are you planning on making and are you going to be launching the car on slicks? If you are going to be putting more then 350 Ft-lbs through the diff, I would recomend getting a gear type LSD or clutch type LSD not a viscous. There are plenty of aftermarket LSD's available for the 300ZXTT and Nismo even offers one with everything you need to install it including instructions and gear lube. If you don't plan on making that much power...why would you even put the R230 in the car? Quote Link to comment Share on other sites More sharing options...
cyrus Posted July 12, 2005 Author Share Posted July 12, 2005 who sell the LSD? nismo, and >? Quote Link to comment Share on other sites More sharing options...
Montoya Posted July 12, 2005 Share Posted July 12, 2005 http://www.nissanusa.com/content/0,,action-NStaticLoader_path-@nissan@nismo@static@nismoLanding,00.html This is the Nismo site for the LSD. MSRP is $900 and you can find them for less at numerous parts suppliers. Quote Link to comment Share on other sites More sharing options...
Montoya Posted July 12, 2005 Share Posted July 12, 2005 http://www.japanparts.com/shop/shop.cgi?mode=itemlist&maker=Nissan&type_car=FairladyZ+Z32&type_second=Engine+and+Drivetrain&type_third=LSD%27s%2fDiffs More diffs at japanparts.com Quote Link to comment Share on other sites More sharing options...
cyrus Posted August 4, 2005 Author Share Posted August 4, 2005 Called Kaaz about a LSD. Will know if the 300ZXTT LSD works soon. Quote Link to comment Share on other sites More sharing options...
Guest 73TPIZ Posted August 4, 2005 Share Posted August 4, 2005 My '05 Titan has the towing package. I believe 2.94 stock and I have a 3.36. My rear is solid axle but possibly the Armada ratios are comparable. I believe the turbo guys on here are always looking for the elusive 3.36 R200 so this could be promising. Found it!!! Go here. http://www.nissannews.com/ Click on Nissan at the top, then Armada, then Specifications. It says 2.937 regular and 3.357 for Off Road or Tow package. Good Luck with it cyrus. Quote Link to comment Share on other sites More sharing options...
