LT-1 PCM through tunercat program
Got my PCM back from being reprogramed, set-up the tunercat program established com-link (no problem) click on toolbar, select "Read PCM" from the menu options (that was the only option available/highlited) It began the process with the warning Not to interupt the program, after approx 30-45 sec. pause, the Red circle w/white "X" and the "Can not read PCM"
So, is my gut correct in assuming that I may have purchased a defective unit to begin with? Dose anyone out there know of a way to test the health of the PCM before I cough-up $117. for the new unit? GM part No.16181333
Make sure that you have the "ignition on" sequence correct.
Turn the ignition on (listen for the fuel pump to quit priming), then start the read procedure....
but....it certainly sounds like a hosed PCM....
