4.6 mounts to 280z?
Guest soon2bturboz
Guest soon2bturboz
my buddy has a wrecked mustang with a 4.6 i was woundering if they made a mount kit to put it into my z. also where could i get them? thanks brett
If you do a search for 4.6 Ford, you will find info such as: it is to wide to fit without any major structural modification in the Z car engine bay. That is the main reason if I remember correctly.
It would be great to have one, go for it !!! And search
Dayz
i work as a ford tech at a dealer.the 4.6 is wide but the spark plugs are in the intake area so once you get the engine in it wont be a problem.exhaust will be a problem on drivers side.if you do the swap get the ford evtm for the original car.the evtm is the wire harness diagram book.nobody else had done a 4.6 yet.the 2000 up motor revs more freely.good luck.iif i was going to do this i would cut the mounts off of the crossmember and build a separate crossmember to hold up the engine to mount it back against the firewall.
