roller Posted July 24, 2005 Share Posted July 24, 2005 my motor does'nt have much vac. so i would like to delete the booster. Quote Link to comment Share on other sites More sharing options...
datsunlover Posted July 25, 2005 Share Posted July 25, 2005 Um.. have you thought this through? My 280 has JUST enough brakes as it is, and evrything is working properly! (Not that it's really that bad, but I go from a 93 king cab to my Z and notice the diffrence really quick) I would not want to drive a Z with no vac booster, and otherwise stock brakes. Quote Link to comment Share on other sites More sharing options...
blueovalz Posted July 25, 2005 Share Posted July 25, 2005 I agree. An improved vacuum signal can be had by leaving the transmission in gear as you apply the brakes (engine RPMs will be above idle for the most part with the throttle plates closed). Vacuum canisters can help as well (they won't increase the vacuum signal, but they will stretch it out longer prior to depletion). I believe there are electric vacuum pumps on the market as well. Quote Link to comment Share on other sites More sharing options...
