At 475 HP, manual trans, W/slicks will a R230V hold up? R200V?
cyrus
I plan to run the car with slicks and do the following:
1 Pull to the dragstrip start line
2 hold the engine against the rev ~7000 limiter
3 side step the clutch
4 change underware
5 repeat
I am wondering if the R200V is strong enough or do I need the R230V. There must be a least 20 pounds of extra weight there.
I'm not that excited to see the video...he's only going to move about 2-3 inches as he'll have a broken stub axle...been there done that. You may get a launch or 2 out of it, but it won't last like that. I cut some 1.5's launhing at about 5600rpm, I went closer to 6000 and broke the stub axle. I know they had some abuse on them, but they won't hold up to repeated launches like that. Be sure to bring extra parts to the track...I do. By the way, I'm running an LS r200 from a 300zx
