Injector settings?
gexgexgexgex
Ok i have a 1973 240z running megasquirt and spark extra an i have 450cc DSM blue top injectors that are low impedence(sp) and i cant seem to find the injector settings for them, this is what i found i and i want to know if it is any where near what they should be, becuase my car does not like to idle right, way too rich
Injector Characteristics
Injector Opening time(ms) 1.0
Battery Volt(ms/v) 0.20
PWM current limit % 100
PWM Time threshold (ms) 25.5
Required fuel 6.9
Ok i have a 1973 240z running megasquirt and spark extra an i have 450cc DSM blue top injectors that are low impedence(sp) and i cant seem to find the injector settings for them' date=' this is what i found i and i want to know if it is any where near what they should be, becuase my car does not like to idle right, way too rich
Required fuel 6.9[/quote']
Strange, my brother who has the 450 blue tops is having the exact same problem. I'm running 440 skyline injectors and had NO problems with my program, loaded my program to his car changed the REQ fuel to 6.9 and he said that he was getting the worst gas mileage that he has ever got. He said that on the way back from Indianapolis he changed the reg fuel to like 4.9 :eek: and told me it ran fine and was getting decent gas mileage... Anyone know more about these 450 dsm injectors?
i'm running dsm 450's
req fuel is 6.8ms
open time = 1.0ms
voltage correct =.1
current limit =100
pwm =25.5ms
what does your map look like at cruize/idle
my cruise is around 42-53kpa
i'm running about 55% volumictric efficent
I'm running around 14.7:1 on the wide band so.
if you want some pictures of my map, constants, enrichments lemme know.
do some logging to see if you need to up your tps voltage threshold. mine had big drops in afr when it got a false accel signal.
jesse
