air regulator do I need it?
Guest Alpha 1
Guest Alpha 1
I have a 1977 280Z mostly stock,mild cam, have header, pallnet fuel rail and TB kit. the question is the hose from the air regulator does not fit the new TB. Do I need the air regulator? what if I removed it? It sure cleans up the intake manifold with it gone.
the Cold Start Injector only affects (richens) for the first 8-12 seconds after you turn the engine over ( and assuming it starts). After the 8-12 second time (controlled by the Thermotime switch), the should close and the fuel mix should be normal). So the Cold Start Injector doesn't need to be removed.
  • 1 month later...
