laurentz Posted August 22, 2005 Share Posted August 22, 2005 I'd like to run a 16x9 -12 front and 16x10 -25 rear with ZG over fenders. I'm running the AZC strut assembly, will I have any issues with rubbing and or fitment? I don't mind running a sligt tire stretch and some negative camber, my main concern is the coilovers rubbing. Thanks, Laurentz Quote Link to comment Share on other sites More sharing options...
Dudeboy Posted August 22, 2005 Share Posted August 22, 2005 Read the specs on Alex's car. http://forums.hybridz.org/showthread.php?t=102754&page=1&pp=25 Quote Link to comment Share on other sites More sharing options...
Phantom Posted August 23, 2005 Share Posted August 23, 2005 The only way you'll get it right is to get under the car with a ruler and take measurements. Everey car is a little different once we start 'working' on them. Measure from the wheel mounting surface to the springs/coilovers and from the mounting surface to the inside of the fender well. That will give you the maximum tire section width you can handle and what offset you'll need to have to run it. While you're there look for anything else that could cuse a problem like brake line positions, etc. - especially in the front where the wheel position changes. Quote Link to comment Share on other sites More sharing options...
zguitar71 Posted August 24, 2005 Share Posted August 24, 2005 Both the front and rear wheels should have a 4.5" back spacing with the offsets you have listed. They should work with the stock suspension or coilovers. Quote Link to comment Share on other sites More sharing options...
