240's are simply awsome.
ZR8ED
Man I forgot how great it is to work on a stocko 240!
My 71 240 is coming along very well. I've worked on it a couple of hours almost every day this week.
Finished list: (its bigger than the todo list)
wired up reverse lamp switch (replaced switch and wires)
balanced carbs
set idle
freed up the throttle linkage (was sticking)
got the license plate light working.
freed up the wiper linkages
plumbed the washer bottle hoses.
mounted 280 front signal lights in the MSA air dam (temporary till I find some nicer lights
Installed new rear carpet.
detailed interior/vacuum
detailed engine bay/clean up
set up timing.
checked/gapped plugs
checked all fluids
rewired fuel pump
replaced some vacuum lines
cleaned grounds/misc wire connections
checked alt volts
checked battery
checked coil
Car is about ready to go.
I need a new master brake cyl rear brakes are contaminated...may need rear cyl, and flex lines.. not sure..
replace manifold gasket. Minor leak.
Install new drivers seat (have one)
move fuel pump location (electric fuel pump now)
Thats it.
It starts easy, idles pretty good except for the mild exhaust leak. Drives nice when it has gas in the tank...(don't ask)
Its a great little car!
