CV Joint
Guest TheHappyHeathen
My car is creaking and groaning from the rear axle, and 'popping.' I want it to be something else, but I have a feeling it's the CV joint. What the hell should I do, I don't even know if I can afford to start replacing drivetrain stuff. Is there any way I can find out exactly what part of my car is making this noise so I can keep from wasting time and money taking **** apart.
i don't know what it's called, but mechanics in the past have used little systems with multiple mics with magnets on them so you can stick the underneath the car so they can drive the car and listen to where the noise is coming from. They're normally used for suspension noise since you many times have to be on the road to create the noise. If it's a true drivetrain issue then skip's idea should work fine, but it's something to look into.
