VE, Spark, and AFR maps for 383ci Chevy V8
dmanzo57
Don, thanks for posting that!
I'm fumbling along trying to get my 406 MS-I map even close. Even though yours isn't 8x8, I can still use it to come close by just leaving some rows and columns out here and there.
Can you provide specs on the engine?
Compression?
Heads? Flow?
Cam specs?
Headers? Size?
Exhaust?
Thanks!
Pete
Guest Loose_Screws
  Quote
Here are the maps for my 383 SBC with Holley Stealth Ram intake and 36lb/hr injectors.
Not perfect' date=' but good for 11.49@119MPH at the track and 19MPG on my commute...
:cheers:
Don[/quote']
11.49 AND 19mpg?!?!?! You spraying it or is the car EXTREMELY light? Congrats! I have only gone 13.1 and get ~25mpg. That was on a previous tune of 230rwhp, now have 292rwhp, but mpg shouldn't have been affected.
Give us some more details on your car and setup!
Engine:
383ci small block Chevy
10.3:1 compression
AFR 190 heads
Lunati hydraulic cam .480 lift, 230@.050 duration
Hooker 1 5/8" block hugger headers and a single 3" Dynomax ultra flow muffler
Holley Stealth RAM intake, 36 lb/hr injectors, LT1 throttle body
Transmission:
2004R w/2400 RPM stall
Diff:
R200 3.54:1 w/clutch LSD
240Z 1/2 shafts w/Neapco Brute Force ujoints
The car weighs about 2825 lbs with me in it. It's a blast to drive! :twisted:
:cheers:
Don
