dj paul Posted September 6, 2005 Share Posted September 6, 2005 http://cgi.ebay.com/EDIS-6-distributor-less-for-Megasquirt-efi-EDIS-4_W0QQitemZ7997273610QQcategoryZ33553QQssPageNameZWDVWQQrdZ1QQcmdZViewItem ive seen something similar on here before but i was just wondering if anyone had experience with this particular one. thanks in advance! paul Quote Link to comment Share on other sites More sharing options...
evildky Posted September 7, 2005 Share Posted September 7, 2005 It's been done and has it's own forum over on msefi.com, I'm tempted to run edis on mine just so I won't have to deal with the HEI's, you gonna megasquirt your Z ? Quote Link to comment Share on other sites More sharing options...
Guest 81na ZX Posted September 7, 2005 Share Posted September 7, 2005 I'm probally going to run an EDIS-4 on a CA18 cause I don't want to mess with the CAS and OEM distributor system Quote Link to comment Share on other sites More sharing options...
dj paul Posted September 7, 2005 Author Share Posted September 7, 2005 ya im gonna run megasquirt. control it with a palm zire 31. =). im just wondering if the benifits would be worth it, because my car came with a crane xr3000 fireball ignition and it is optical triggered. Quote Link to comment Share on other sites More sharing options...
evildky Posted September 9, 2005 Share Posted September 9, 2005 well if it came with the fireball and an optical sensor I'd just run it, you staying N/A or going turbo? if you go turbo you'll have to lockdown the dist unless it's a non advance unit Quote Link to comment Share on other sites More sharing options...
Guest ON3GO Posted September 9, 2005 Share Posted September 9, 2005 i have the stock DIS system from the 280ZX... Chris on here gave it to me cuz he is a great friend and loves me dear... did a search on it and found really nothing, was told it came on a one year only 280zx turbo, and thats all i know. can take pics of it if needed. mike Quote Link to comment Share on other sites More sharing options...
evildky Posted September 9, 2005 Share Posted September 9, 2005 yeah the crank fired 81's hasn't been used with msns to my knowlege, I'm sure it's basically the same, I can't imagine datsun would have changed what kind of trigger signal they were using Quote Link to comment Share on other sites More sharing options...
mario_82_ZXT Posted September 10, 2005 Share Posted September 10, 2005 evildky said: yeah the crank fired 81's hasn't been used with msns to my knowlege, I'm sure it's basically the same, I can't imagine datsun would have changed what kind of trigger signal they were using I think Tony D is running it..... I think so are a handful of others. Mario Quote Link to comment Share on other sites More sharing options...
240jz Posted September 10, 2005 Share Posted September 10, 2005 This may be a slightly stupid question but I have never had to take my motor apart yet and I don't yet know. Is the oil pump driven off the distributor? It would seem to be a small problem if it is. Quote Link to comment Share on other sites More sharing options...
evildky Posted September 10, 2005 Share Posted September 10, 2005 it's a kind wierd set up the shaft is driven by a gear on the crank and it turns both the oil pump and the dist, you can remove the dist and cap the opening (as at least a few have done) and everything still works fine Quote Link to comment Share on other sites More sharing options...
dragoontwo Posted September 10, 2005 Share Posted September 10, 2005 Quote i have the stock DIS system from the 280ZX...Chris on here gave it to me cuz he is a great friend and loves me dear... did a search on it and found really nothing' date=' was told it came on a one year only 280zx turbo, and thats all i know. can take pics of it if needed. mike[/quote'] Quote Link to comment Share on other sites More sharing options...
