Phyxius Posted September 9, 2005 Share Posted September 9, 2005 is it possible to bore cylinders with a hone? yes, i realize paying someone to do it isn't that expensive... No, i'm not building an engine atm....these are just things i've been wondering about Quote Link to comment Share on other sites More sharing options...
GLENN280ZX Posted September 9, 2005 Share Posted September 9, 2005 You Can, If The Cylinders Are Worn Close To Very Worn Out Specs. To Try And Hone Alot Of Mat. Would Be Detrimetal To The Stones And Alot Of Heat In The Bore. Quote Link to comment Share on other sites More sharing options...
dr_hunt Posted September 10, 2005 Share Posted September 10, 2005 Why would you want to do that? Quote Link to comment Share on other sites More sharing options...
Phyxius Posted September 10, 2005 Author Share Posted September 10, 2005 no particular reason.... i was just wondering if it were feasible Quote Link to comment Share on other sites More sharing options...
2126 Posted September 12, 2005 Share Posted September 12, 2005 is it possible to bore cylinders with a hone? yes' date=' i realize paying someone to do it isn't that expensive... No, i'm not building an engine atm....these are just things i've been wondering about[/quote'] Technically speaking, a hone hones and a boring bars bore. When using a hone, it relies on the condition (shape) of the cylinder and will follow that condition for the most part. Basically, without boring a cylinder and using only a hone, you will not have precise control of the process. Spend the money and do it right the first time. Sometimes cutting corners is a sure way for spending more money in the long run! Quote Link to comment Share on other sites More sharing options...
