big block does fit
Project BBZ, I would recommend that you mock-up the exhaust tract from the heads back toward the transmission tunnel area, as early as convenient in the car's construction process, to check starter interference, clearance around the bellhousing, etc. Things may turn out to fit perfectly - or they may not. It might be necessary to cut sheet metal, buy a different starter, relocate the steering shaft, and so forth. It might even be necessary to move the engine back or forth slightly.
