thermodynamics question HELP PLEASE
260ZRED
Guys... can you help me out with this one? I have air, to be treated as an ideal gas @ 8 bar and 600K. I need to find either the density or the specific volume (which is just the inverse of density...)
I do NOT know the actual mass or the actual volume, but I need to find the specific volume, to find mass flow rate @ steady state. I have the area and Velocity, just need the sp.volume...
Can I do this: Pv=mRT with (R=Rgiven/M)
So,
v/m=[R*T] / [P*MolarMass of air]
v/m=specific volume, right?
Is this the right way or not??? I'm really confused..
Thanks for any help about this.
Igor
the short answer is yes. pv=RT will give you what you want.
p= absolute pressure
R= R-bar/M
R-bar=universal gas constant=8.314 KJ/Kmol*K
M= molecular wight of air=28.97 kg/kmol
T=absolute temp
the long answer is that you are going to have to make sure your units work out. as it is currently 1:23am, i'm not going to do that for you.
hope this helps,
--gabe
Gabe beat me to it, so just to elaborate… use the “engineering form†(as opposed to the chemistry form) of the ideal gas law, P = rho*R*T, where rho is density. In S.I. units, the UNIVERAL gas constant is R = 287 J/(kg*K). So, rho = P/(R*T) = 8*(101325 N/m^2)/(287J/(kg*K) * 600K). The 101325 N/M^2, or 101325 Pa, is atmospheric pressure at STP. Units cancel to give kg/m^3, and the numerical answer is 4.707 kg/m^3.
