240 SX TPS (switch/sensor or both)
74Adam
Guys, I'm looking at this TB on ebay:
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=8003046533&sspagename=ADME%3AB%3AAAQ%3AUS%3A1
Can you tell from that pic if it is the one with only a sensor output or the sensor/switch combo? I am new with the EFI stuff so I'm trying to learn. I did a search but couldn't find any pics. I got a response from the seller, but he doesn't seem to think it is his resposibility to know.
thanks,
-Adam
Nissan used the outer lever for the cruise control function and the inner one for the accelerator pedal function.
The outer lever is positioned further away from the shaft than the inner one so the mechanical lever advantage is more. The cruise control is powered from a vacuum diaphragm so it may need the added leverage.
I followed Nissan's method when I used the 240SX TB.
