pjo046 Posted September 29, 2005 Share Posted September 29, 2005 For those of you who doesn't already know, I am building a 240Z with a heavily modified L28ET in it. I will run a 3" downpipe and 3" piping back to a oval magnaflow glasspack muffler that has a total length of 14" and a internal core length of 7". I was thinking of perhaps add another resonator/glasspack on the straight pipe in the trans tunnel, just after the transmission. Will a round glasspack muffler fit there if it has a 6" outside diameter? Or will this interfere with either the ground clearance or the drive-shaft? You see, I want to tone down the exhaust note more than on my last Z. That one was too loud. I still want a nice roar when I hit the gas pedal though, but when cruising I want to be able to speak and listen to music etc. Have a quiet ride when cruising in other words. If the glasspack I am talking about won't fit, do any of you have other suggestions??? Quote Link to comment Share on other sites More sharing options...
Lewis Maudlin Posted September 29, 2005 Share Posted September 29, 2005 I think your glasspack will fit. The only problem would be height and dragging it over rocks in the road. I had 2 blue turbo glasspacks in the tranny tunnel on my sbcz. They are 4" diameter. Quote Link to comment Share on other sites More sharing options...
pjo046 Posted September 29, 2005 Author Share Posted September 29, 2005 Hmm. Wish magnaflow made 4" glasspacks with 3" inlet and outlet... I want a stainless steel glasspack, and also I have a large order at summit now, so thought I'd add one to my order before it ships. Summit has some glasspacks that I think has a 4" outer diameter, but they are regular steel... :-/ Quote Link to comment Share on other sites More sharing options...
Phantom Posted September 29, 2005 Share Posted September 29, 2005 My california version 77 280Z came with a catalytic converter in the location you'r talking about. It was about 4" in diameter and did double-duty as a resonator. As long as th ecar isn't lowered you'll be Ok - otherwise you need to look for more options. Spend some more time with Google and "mufflers" or "resonators". You'll eventually find what will work. I found that some good sound deadening material inside the cabin gave me the same end result plus eliminated a lot of other noise. Quote Link to comment Share on other sites More sharing options...
pjo046 Posted September 29, 2005 Author Share Posted September 29, 2005 Yes, I am going to sound deaden the interior. But I want to avoid sounding to loud for other people outside as well. Quote Link to comment Share on other sites More sharing options...
