Lewis Maudlin Posted October 6, 2005 Share Posted October 6, 2005 Anyone running A/C in an SR20DET powered first gen? Mine is about complete except I am having trouble getting the engine in with the A/C compressor. I like A/C. There are clearance issues however with the steering shaft. Anyone tackle this before? Anyone have any suggestions? Quote Link to comment Share on other sites More sharing options...
SR240Z Posted October 6, 2005 Share Posted October 6, 2005 im 99.9% sure that none of the sr20 powered S30 cars have a/c Quote Link to comment Share on other sites More sharing options...
Guest PROJECTRB240SX Posted October 6, 2005 Share Posted October 6, 2005 Heim Joints Are About The Only Thing You Can Do To Get Clearance For The Compressor..... Well That Or Hydraulic Steering! Quote Link to comment Share on other sites More sharing options...
Lewis Maudlin Posted October 6, 2005 Author Share Posted October 6, 2005 Well, I guess I will be the first one with A/C. How do you guys live without A/C???? Toys are great, but function is even better. Quote Link to comment Share on other sites More sharing options...
SR240Z Posted October 6, 2005 Share Posted October 6, 2005 in southern california A/C is not always needed unless its insanely humid or stuck in traffic, without a/c saves uneeded weight and frees up drag on the motor Quote Link to comment Share on other sites More sharing options...
Guest PROJECTRB240SX Posted October 7, 2005 Share Posted October 7, 2005 Try drovong in Arizona during 120+ degree days with no A/C..... Its Great! You'll get used to it.... Every car I have owned in the past 3 years has not had A/C. Quote Link to comment Share on other sites More sharing options...
fastzcars Posted October 7, 2005 Share Posted October 7, 2005 Put the a/c in lewis. I put a VintageAir unit in. And I don't regret it, it sure makes the car much more comfortable around town in traffic. Quote Link to comment Share on other sites More sharing options...
Lewis Maudlin Posted October 7, 2005 Author Share Posted October 7, 2005 I will have A/C in my car. Mine is a daily driver and is useless without A/C for a few months of the year. Does anyone have any suggestions? Will the Vintage Air unit still need the compressor in the same location on the SR block? I think the SR and the steering rack are not going to accomodate the stock A/C compressor. Any ideas better than "towing a car with A/C and piping the air into my car" would be appreciated. Quote Link to comment Share on other sites More sharing options...
fastzcars Posted October 7, 2005 Share Posted October 7, 2005 Lewis. Is the problem with the compressor monut to the block? Is it that the stock location will not fit in the engine bay? The evaporator inside the cockpit doesn't care ware the compressor is, as long as you can make a hose long enough to reach it. For example my hoses from the inside exit the passanger side of the engine bay and the compressor is at the driver side of the engine. I have a 6 foot long hose aroung the back of the motor to connect the two. Maybe Alex (SR240) would know of a front wheel drive platform that would have an sr20 engine that you could use a bracket off of. Quote Link to comment Share on other sites More sharing options...
SR240Z Posted October 7, 2005 Share Posted October 7, 2005 you would definitely need to make your own bracket to mount the A/C compressor away from the steering shaft, i doubt another sr20 bracket would place it anywhere else other than the bottom of the block which would still put it in the way of the shaft. maybe you can find a smaller compressor and then make a custom bracket for that to fit. Quote Link to comment Share on other sites More sharing options...
