twistex Posted October 7, 2005 Share Posted October 7, 2005 ok im tryin to get my megasquirt up and running. i been reading to test board with the tester you have to jump x11 to x whatever but then it says to undo it and jumper x11 to spr4 so the - coil signal will work. anyone have a easier way of explainin how to get it to work ? im using the black dizzy module dist. using megasquirt for fuel only, not spark. thanks Quote Link to comment Share on other sites More sharing options...
envmyz Posted October 7, 2005 Share Posted October 7, 2005 pin 24 goes to tach input (- side of coil) I would recomend adding a pullup resistor also. Quote Link to comment Share on other sites More sharing options...
twistex Posted October 8, 2005 Author Share Posted October 8, 2005 i ment i need to know what to jumper on the pcb board to make the pin 24 work with the negative coil. Quote Link to comment Share on other sites More sharing options...
