megatune & extra for v3pcb?and inj. problem
boostin280zx
i have megatune2.25b514 and extra024s9a. With this i could never get spark output off pin 36. I set one of the LED's to spark output and wired the negative off that to pin 36. That has worked and i am getting a good spark. Does anybody know if thats a good enogh ground to trigger a gm hei 4 pin module with or will i burn something up eventually.
Anyone know why my injectors open up as soon as i turn ms on? They dont close. It leaks all the pressure out of the fuel lines into my motor. What drivers should i check on the board? Im pretty sure my inj. wiring is right.
