Ouch
GOTHALOSISM
Well its time for me to post that I of all people do not know what in the heck i am doing... I decided to drive my car to work today and heard this popping noise. Of course i had almost no power. So what i did was check my cylinders, and guess what i found out.... I'm running on 2 of the 6... ouch... now come s the fun part I have no idea what i should do to fix this problem.... Is it change the head gasket or spark plugs first??? Any help would be much appreciated...
________________________________
1979 280zx (snot rag)
I would check your spark plugs, spark plug leads and distributor cap (I found I was running on 5 cylinders because 1 of the leads came out of the distributor cap). Any one of those can stop a cylinder from firing. When you lost the 4 cylinders, was it all at once, or was it gradually getting worse?
check is you have spark by checking ayour connections from cap to plugs, while the engine is running remove the wire from a plug and hold it about 1/2 inche from the plug. if you have spark, you should be about to see a spark arc across to the plug. repeat with the other plugs. if no spark then either the plug needs to be replaced or the rotor/cap needs to be replaced. not really all that expensive, probably about $40.
