Fuel light
big-phil
is it a 280z?
There should be a three pin connector on a harness going to the gas tank. Unlplug that connector, grounding one of the pins going into the harness should turn the light on if the key is in the "on" position. Dont worry about grounding the wrong pin, as it shouldn't hurt anything. This will prove your light works, but the only way to prove the sender is working is to let it run low.
