TOMAHAWKZ Posted October 28, 2005 Share Posted October 28, 2005 Any of you guys out there interrested in a power steering delete bracket and pulley set up to fit in the stock location of your LT1 swap. I am currently in the proto type stage and I am trying to guage how much interest is out there. Quote Link to comment Share on other sites More sharing options...
love-my-V8-280Z Posted October 29, 2005 Share Posted October 29, 2005 When I was looking at what I wanted to do with my LT1 I reviewed all the options.. It boiled down to did I want a/c or not.. I figured I might so I did the mods necessary to mount the a/c on top... I would sudjest to anyone that has to go through the work of modifing the belt and pulleys to just go with the a/c setup.. Its only a option, but before you go thorough the work make sure you are not going to change your mind. And if you do want A/C I will more than willing give you what you need to make your own brackets... Quote Link to comment Share on other sites More sharing options...
Bartman Posted October 30, 2005 Share Posted October 30, 2005 When I was looking at what I wanted to do with my LT1 I reviewed all the options..It boiled down to did I want a/c or not.. I figured I might so I did the mods necessary to mount the a/c on top... I would sudjest to anyone that has to go through the work of modifing the belt and pulleys to just go with the a/c setup.. Its only a option' date=' but before you go thorough the work make sure you are not going to change your mind. And if you do want A/C I will more than willing give you what you need to make your own brackets...[/quote']I'd be interested in seeing what you've done for AC. My power steering pump is gutted, but still in place. How does putting on AC affect the power steering pulley setup? Quote Link to comment Share on other sites More sharing options...
TOMAHAWKZ Posted October 31, 2005 Author Share Posted October 31, 2005 I have an A/C delete bracket and pulley on my engine. I decided not to keep the A/C because my car has no roof! Go figure the guy that designed my kit bulit a removeable roof a few years later which I now also own so I may do a retrofit and put a/c back in before the car goes off for paint. My problem is I can not put the a/c on the top of the motor due to hood restrictions and side pipe headers are in the way.. But where theres a problem... There is always a fix.. Stephen Flying Dutchman Motorwerks Quote Link to comment Share on other sites More sharing options...
