Pull differential from a Q45
kraymond
Same thing as every other diff: Your ratchet, box 12mm, 17mm, 19mm, and 14mm I believe. You also need wrenches of the same size, for the flanges and the drive shaft. You need a breaker bar( or a pice of pipe with the ratchet) some vise grip to block some bolts from turning (drive shaft bolts) a 34mm or 36 mm to take the axles out. A long pry bar for blocking the wheel when trying to pull axle nut out. You will also need a beer for the break time (after you hit your knuckles). The whole process will take you 1-2 hours.
Good luck
