looking for a fuel pump bracket
The Rototiller
does anyone have a stock fuel pump bracket from a 73 240z or a 74 260z that they want to get rid of? let me know.....i am looking for one to mount a holley red pump to. thanks
I put that same pump in my 71 and used the 280Z fuel pump
bracket. It was a perfect fit and the holes were even there
for the bracket. Be sure to put a Fram G3 fuel filter between
the pump inlet and tank.
Bracket on my 1972 is standard from factory. Looks different than your drawing. Plug and play. What year do you have?
It looks like that bracket will only work with a R180 that has the
mustache bar in front of the risers. The 280Z pump bracket still
bolts to the holes that are in the 240Z but sits back far enough
to clear a R200 mustache bar that sits behind the risers.
