280ZXT What not to remove?
Guest RaiZed
I am doing a complete teardown and custom rebuild of my 82 280ZXT AT.....
What emmisions components and other stuff can I remove and still blow passing emmisions? EGR valve? and any other stuff I dont need?
Im going for super simple here guys!
The only power option I am gonna have is power windows!
If I dont absolutely need it I dont want it!!!!!!!
I want to be Just legal enough to pass emmisions and get a tag. ya know...
I want everything needed to be controlled by a main switch panel....
No A/C
No Heat
No cruise.
Converting power steering to manual.
Electric water pump
So far I have shaved exactly 182 pounds from the A/C / Heat and ALL the little stuff. I actually weighed it ALL as it came off the car! LOL
Im sure theres another 20-30 lbs in un needed wiring and relays and , and ,and? :o) Im sooooooooooo EXCITED!
I was hoping to simplify my '82 Turbo too. It's so darn complicated with all those hoses and wires and sht going everywhere. But since I'm in CA, with some of the strictest laws, I'm scared to touch anything. So I too am interested in finding out what bits I can remove, or at least convert to something neater.
Nothing that I know of says you can't reroute the zillion vacuum lines that run over the top of the motor. That is what I did when I was worried about passing the test. These motors are not the cleanest running motors so even removing one peice will put you over the edge in my experience. If you are looking for more power then I tell you it can certainly be had even with all the emisions equipment inplace.
personally I like my extra power accessories, but I didn't like the A/C, Cruise, and all of my emissions. Hey since your trashing your cruise you sould do a cable conversion. I did and love it, you'll need to do some custom fab work on the pedle, on the hole in the fire wall, and need to get a 84 200sx throttle cable.
tbs
