Danno74Z Posted November 24, 2005 Share Posted November 24, 2005 I might be comparing apples to oranges but does anyone have reliable information on the HP output to both the stock 95LT1 and the ZZ4 engines. I can’t seem to find (might not exist) information on the LT1 as a bone stock engine as compared to the ZZ4 crate engine. I know the specs for each but they are not equivalent. Any help would be most appreciated – Happy Turkey Day To All! Danno74Z Quote Link to comment Share on other sites More sharing options...
jack46 Posted November 25, 2005 Share Posted November 25, 2005 Tere are basically three main variants of LT1: The Impala, Camaro and Corvette. The Impala/Caprice/buick/Caddy were all iron headed and had ~260 RWHP. The Camaro was aluminum headed and had ~285 RWHP. Finally the Corvette had 300 RWHP higher mainly because of better intrake and exhaust. Here is a good sitre for some LT1 information LT1 rebuild LT1's are getting reasonable now and with harness and electronic overdrive make a nice transplant combination. Good luck Quote Link to comment Share on other sites More sharing options...
Danno74Z Posted November 25, 2005 Author Share Posted November 25, 2005 Thanks for the info about the LT1. I'm interested in the 95 LT1 from a Camaro - CI block with Alum. head version compaired to the ZZ4 engine. Can't seem to find anything that can say which engine is more powerful - stock to stock output. I not sure but I belive the ZZ4 used the L98 alum. head. Likewise the LT1 had better heads but used a milder cam then the ZZ4. Probably a wash when it's all said and done Danno74Z Quote Link to comment Share on other sites More sharing options...
Danno74Z Posted November 25, 2005 Author Share Posted November 25, 2005 I found what I was looking for in Super Rod. The stock LT1 stripped to the bare necessities was dyno rated at 363HP &390LB-FT of torque. The ZZ4 is rated at 355HP and 406LB-FT of torque. I would say these engines are very close to each other. Quote Link to comment Share on other sites More sharing options...
Pop N Wood Posted November 25, 2005 Share Posted November 25, 2005 If I were you I would consider the 385 fast burn engine over the ZZ4. Only another 30 HP over the ZZ4, but better heads. Add a cam and roller rockers and you get 430 HP. http://www.sdpc2000.com/catalog/1578/products/2598/Fast-Burn-385-w-LT4-Hot-Cam-Upgrade-High-Performance-Series-Street-and-Strip-Engine.htm In my opinion, the big differnce between the two engines will be price. Pull a used LT1 and you get a complete, fuel injected engine and tranny combo for well under 2 grand. A complete ZZ4 combo might run $7k for just the engine, and that will be carb'd and not FI. http://www.sdpc2000.com/catalog/1578/SDPC-High-Performance-Series-Street-and-Strip-Engines.htm Quote Link to comment Share on other sites More sharing options...
Danno74Z Posted November 25, 2005 Author Share Posted November 25, 2005 Hi Pop N Wood, I have a stock 95 LT1 & T56 out of a Camaro (w 25k) waiting to go into my Z. I've had the engine for about 4 years now in storage and it is time to move on the project. Too many other life issues but I won't get into that! I was just curious on the power made between the two engines - stock to stock comparison. Naturally, with better heads, cams and $ the sky is the limit with either engine. As a side note, the LS1 engine produces about 50 hp more then the LT1 right from the start. It also is more expensive to purchase either from a Chevy dealer or the wreaking yard. From what I can tell through my readings the LS1 has better heads, cam, and intake then the LT1. If someone wanted to spend ~ $2K on the LT1 engine with say AFR195 heads and a CC cam, power levels surpass the stock LS1 and then you get into how much money you want to spend for additional HP and torque. I have a friend who has a Z car with the ZZ4 and T56 combo in it and it is scary fast even here in CO at 5K feet. Power is down 20% because of the altitude but you can't do a whole lot about that. Quote Link to comment Share on other sites More sharing options...
