240z steering angle mods?
The main limitation to getting more steering angle is the TC rod. You'll find that unless you have some really offset wheels that the wheel hits the TC rod when cranked. I'd check for clearance before you went modifying. One solution would be to build a custom front control arm that worked like the ones on a 944 and integrated the TC rod and the control arm into one unit. This would potentially provide more room for the wheel to turn.
To answer your question, I believe the short steer knuckles give more steering angle than the stock length ones.
