240SX subframe question
Hello everyone,
So I have the 240SX subframe installed on the Z but I need coil-overs. The 240SX coil-overs are about 3.5" too short. What have others done in the past to correct this problem? I can machine spacers but I think that would be a waist of time. How much do custom coil-overs run? I assume I just need a long enough shock body and I could make them using Ross's or anyone elses coil over kit.
Check out my gallery for some pics of the install.
  Quote
what year subframe did you install? 89-94 s13' date=' or 95-98 S14?
S14 has longer rears, so try that.[/quote']
I installed the S13 rear because it is slightly narrower (sp?). Thanks for the info regarding the S14 shocks, I'll try them out but I need about 3.5" more length. Thanks again
Jon
