oinojo Posted December 15, 2005 Share Posted December 15, 2005 alright im a newb when it comes to talking about electrical so bare with me. How exactly am i supposed to connect the resistor in between the Tach wire (pin24) and the Fidle (pin30). What i did was wrap the wire around the ends of the resistor. It sounds sketchy but i have no clue exactly how it should go and it would explain some or my MS wiring/connection probs. Quote Link to comment Share on other sites More sharing options...
Thumper Posted December 15, 2005 Share Posted December 15, 2005 http://forums.hybridz.org/showthread.php?t=102244 Look at the second diagram if you still have problems im me. Quote Link to comment Share on other sites More sharing options...
trippintl0 Posted December 15, 2005 Share Posted December 15, 2005 i used crimp connectors, and just inserted the ends of the resistor in with the wire and crimped it. (i didn't crimp the resistor wire by itself, i stuck it in with the wire i was attaching it to) Quote Link to comment Share on other sites More sharing options...
ngrimm Posted December 16, 2005 Share Posted December 16, 2005 I like to have a mechanical connection ie crimp or twist connection, and then solder. What I do is put a short piece of shrink tubing on the wire, twist the wires together as small as possible, solder therm together, slide the shrink tubing over the soldered area, heat the tubing to shrink it. IMHO Shirink tubing is a must since electrical tape will come off eventually. Radio Shack sells packages with several sizes. I always use it when making cables as well. All it takes is one strand of wire to create a fatal short. Norm Quote Link to comment Share on other sites More sharing options...
