jtmny1999 Posted December 20, 2005 Share Posted December 20, 2005 Hi guys, This is my daily driver yesturday driving down the freeway I gunned it, all of the sudden won't go into any gear 1st 2nd reverse. So I had to tow it home I checked the tranny oil seemed ok not muddy or shavig so the frictions disks should be fine. So i decided to put it on Jacks I put the car into drive then try spinnig one wheel to see if the other would spin but it won't. That makes me believe that the final drive or the axles broke. I also hear the sound of marbles when i spin the wheel. Do you guys think its work changing the tranny? maybe if I am lucky the axles are broken and i can just replace them. Anyways if its not the axles then I might just sell the car the motor is good had it changed 2 yrs ago. below 100000 miles. What do you guys suggest to do ? Quote Link to comment Share on other sites More sharing options...
AK-Z Posted December 21, 2005 Share Posted December 21, 2005 I thought that 92 sentras were was front wheel drive. From the sounds of it, it sounds like your tranny is shot, or you tourqe convertor is shot (automatics don't have clutch disks). If the wheels can move in any gear then that means that it has something to do with the tranny/torque converter. Usually only one axle brakes when they do, so one wheel should be able to move when in gear on jacks. Oh It could just be you differential also. Quote Link to comment Share on other sites More sharing options...
