clutch suggestions
mom'sZ
You need to learn how to heel toe if you're leaving a black stripe when you downshift, and that has nothing to do with how strong the pressure plate is. The best test for a pressure plate is to go about as slow as you would want to go in 4th gear, preferrably uphill. Then push in the clutch, rev up the engine and drop the clutch. If the clutch is weak it will slip. If it isn't it will instantly pull down the engine rpms.
The Daikin is just called the "Heavy Duty" and it requires a 240mm flywheel.
