Zoldman Posted January 8, 2006 Share Posted January 8, 2006 I just finished the JTR LCA mount relocation and installed poly bushings. All went fine, so I lubed 'em up and bolted everything together. The bushing are real a real tight fit and it takes some effort to move the control arm through its range of travel. Not "leaning on it, vein popping" effort, but the arms will not fall on their own if you pick the corssmember off the ground. No real rough spots in the travel, just a consistent resistance. Just wondering if this is ok, or should they move up and down easy; like fall on their own from the top?? Thanks for the help Bill Quote Link to comment Share on other sites More sharing options...
JMortensen Posted January 8, 2006 Share Posted January 8, 2006 That sounds like normal poly bushing stiction. Quote Link to comment Share on other sites More sharing options...
