CantZme Posted January 10, 2006 Share Posted January 10, 2006 well my z is coming along slowly, but a huge step will be taken as soon as i find out which ngk spark plug to use on my l28et for my setup. The motor is from an 83zx with hydraulic lifters. I will be running msns-extra v2.2 with a t3/t04e not sure on specs(came with the car), fmic with 2.5in cold and hotside. 3indp, 3in exhaust, 437cc/min ford injectors, 60mm tb. I plan on runnning a very conservative tune at about 10-12psi, but would like to turn up boost to 15-17psi with water/meth injection and a new hg. My real question is what spark plug i should use and what i should gap it at...i see so many different opinions and setups that i dont really what to do. Feel free to chime in with any helpful info. Quote Link to comment Share on other sites More sharing options...
EZ-E Posted January 10, 2006 Share Posted January 10, 2006 This is just an opinion but I would suggest starting off with the BPR7ES, it is one step colder and set it at about .030. That should do you well enough. The only thing I found is when running with a colder plug is a little bit of miss at idle, it is very subtle. What I did that corrected this was to install the iridium version of the same NGK plug. Quote Link to comment Share on other sites More sharing options...
HadesOmega Posted January 21, 2006 Share Posted January 21, 2006 with your mods I would just go with what EZ-E said NGK plug one range colder if your setup is near stock I'd just stick with the stocker plugs. Quote Link to comment Share on other sites More sharing options...
