Lewis Maudlin Posted January 12, 2006 Share Posted January 12, 2006 OK, here is where I am stuck. The fuel injectors do not fire unless I pull out the crank angle sensor. The coils fire. If I pull out the crank angle sensor and turn the engine over by hand, the coils and injectors both fire and the car runs but crappy. Anyone know? Is there a more complete wiring diagram available anywhere? Quote Link to comment Share on other sites More sharing options...
Hypertek Posted January 13, 2006 Share Posted January 13, 2006 http://nissanperformancemag.com/march04/240sr/ Did you consider maybe its a faulty ignitor chip? Quote Link to comment Share on other sites More sharing options...
Lewis Maudlin Posted January 15, 2006 Author Share Posted January 15, 2006 Could a faulty ignitor chip cause my symptoms? It will fire and run poorly when hand turned with the crank angle sensor pulled out. It will fire the coils but not the injectors with the crank angle sensor inserted all the way. Quote Link to comment Share on other sites More sharing options...
Lewis Maudlin Posted January 18, 2006 Author Share Posted January 18, 2006 Got it fixed. Tracked down a new wiring schematic. Had wrong 12+ hooked up. Quote Link to comment Share on other sites More sharing options...
