Guest SouthGaZX Posted January 29, 2006 Share Posted January 29, 2006 is it possible for the distributer to be installed off by a tooth or two? i finally got the engine to fire up again... but i have to turn the distributor clockwise so that the hole on the base of the distrib is covered by the left edge of metal that makes up the slot... its like the base needs to be turned 1/4 clockwise so that the cap lines up right... any comments or help would be appreciated Quote Link to comment Share on other sites More sharing options...
Guest SouthGaZX Posted January 30, 2006 Share Posted January 30, 2006 does the timing need to be reset? it runs like crap.. i have 2 or 3 AFM's that i've tried.. same results with the black cap off it just kinda floats open and shut.. bouncing back and forth.. i drained the tank.. put fresh gas in (am going to change the fuel filter tomorrow) i just dont get why the cap would have to be turned so far clockwise to get it to run.. unless the rotor isnt pointing at 1 at TDC after i checked the plugs 4 or 5 were wet.. one or two were dry.,. which makes me believe also it could be one or two bad injectors.. Quote Link to comment Share on other sites More sharing options...
Turbo280Z Posted February 3, 2006 Share Posted February 3, 2006 yea ur timing might be off. try setting it again so its in the right spot Quote Link to comment Share on other sites More sharing options...
Nismo280zEd Posted February 3, 2006 Share Posted February 3, 2006 on the 280z it is VERY easy to put the dizzy down on the wrong tooth, jump it back one and try again. -Ed Quote Link to comment Share on other sites More sharing options...
