JessZ Posted January 30, 2006 Share Posted January 30, 2006 What I've checked: gas filter, distributer cap. The deal here is: i will start the car and drive, and every-so-often my rpm needle will spazz out and the car will want to die. If I pump the gas the motor will usually come back to life. However, if the car does die, and I click off the ignition then turn it back on it will drive again until it decided to repeat this process. problems: points, wires, gas pump, distributer cap. Any thoughts anyone. thanks... Quote Link to comment Share on other sites More sharing options...
2126 Posted January 30, 2006 Share Posted January 30, 2006 You might be a bit more specific......like, what engine you are talking about, is it in tune or when was the last time you did a complete tune out?, ect., ect.!!! Quote Link to comment Share on other sites More sharing options...
