MIBPreacher Posted February 2, 2006 Share Posted February 2, 2006 If you read this and own a 1986-89 300zx non turb, please respond, what is your normal oil pressure as seen on the gauge? Thanks Mine ranges from around 28 to 35. Is that normal? Quote Link to comment Share on other sites More sharing options...
triple B Posted February 2, 2006 Share Posted February 2, 2006 well i guess it depends on what weight oil you run in it. mine runs around that when i am running 10w40 in it during the cold months and in the summer it runs a little higher, but not much, when i run the 20w50 in it are you having a problem ? Quote Link to comment Share on other sites More sharing options...
Guest Gus86ZX Posted February 9, 2006 Share Posted February 9, 2006 Mine runs a little higher when the oil is warm and alot higher when the oil is cold, 10w 30 high milage Penzoil. 86 300zx na, 5 speed with 140,000 miles Quote Link to comment Share on other sites More sharing options...
