Weak Spark on 280Z
Guys, I'm running new NGK wires, new cap, rotor, plugs and an MSD Blaster 3 coil. The trouble is that my spark is pretty weak which may be the cause of one of my cylinders not firing. I tried swapping out plugs, wires, and coils, and that didn't help. I then tried connecting the coil directly to the battery, which still didn't improve the situation (although surprisingly enough the car ran the same with the ballast resistors bypassed). Do any of you know of a sure fire way to get stronger spark out of a mechanical ignition setup like that on the 280Z? Any advice would be appreciated. -Mike
As long as your getting a full 12v to the coil, i would look at the other end, mabe take a test light and connect it to the positive on the battery and test the neg side of the coil (without the coil connected) to see if you have ground leakage, that could cause a partial collapse of the field withing the coil.
