Stock 240 Rear End
Guest mofaster
Guest mofaster
I'm putting either a Ram Jet 350 or a screamer of a 327 in my '71 240. I want a rear end that will handle up to 425 lb ft of torque but i want to maintain the independent suspension. How much torque can a properly rebuilt stock rear end take?:burnout:
A thorough search will net a ton of information and discussion about the R200 (later model Z rear end assembly), as well as the typical modifications using Nissan parts (or others) that are stronger than the OEM set-up. Key words:
R200
R230
axle
There is just too much to explain even in a long paragraph, but suffice it to say the R200 assembly has held up well behind many HybridsZs, and not as well behind a few others.
