300zx ECU question
MIBPreacher
I found the section in my manual that shows how to check the codes, didnt realize i had to unbolt it. I unbolted the ECU and pulled it out, I turned on my Ignition and I saw the following flashes (if I remember correctly)
1 flash together (red and green)
1 red 4 green (the speed sensor circuit is open)
2 flash together (red and green)
2 red 3 green fast (idle switch signal circuit is open)
4 red 3 green fast (throttle sensor circuit is open)
4 flash together
5 flash together
then it starts all over again.
I erased the codes by pulling the negative cable for a couple of seconds, I plan on checking the codes again tomorrow to see if they are still there now that I have driven it to work and back. What do you all think about the codes?
Guest crowbar
You have to be in mode 3 to get codes for the 87-89 ecus. It allows you to select the mode by changing the rotary pot. You seem to describe it just cycling through the modes.
When it cylces so that red-green flash together 3 times (mode3) turn the pot with a small screwdriver.
Then record the codes down.
