Z24O Posted February 24, 2006 Share Posted February 24, 2006 anyone know whether headers and inlet manifold on a set off boss 4V 302 heads will fit standard windsor heads(ie are windsor and boss heads interchangeable as far as inlet/exhaust go)?? Quote Link to comment Share on other sites More sharing options...
blueovalz Posted February 24, 2006 Share Posted February 24, 2006 Completely different. The runners are vastly different sizes, and the water passages are different as well. You'll need the boss intake for what you have. I believe the Cleveland line of exhaust manifolds will fit as well as headers, will bit the exhaust side, but remember, the block on the 302 is smaller, so the header may hang lower as a result. Quote Link to comment Share on other sites More sharing options...
cobraz240z Posted February 24, 2006 Share Posted February 24, 2006 bOSS 302 IS ACTUALLY A 4 BOLT MAIN 302 WITH CLEAVLAND HEADS. IF YOU WANT TO MAKE YOUR OWN BOSS YOU NEED TO DO SOME HEAD MODIFICATIONS BUT IT IS NOT HARD, I BUILT ONE FOR A FRIEND AND WORKDED OUT REALLY GOOD. YOU SHOULD FIND EVERY THING YOU NEED 2 KNOW HERE http://tomsmustangbarn.tripod.com/sbossbuild.htm Quote Link to comment Share on other sites More sharing options...
331CI 280z Posted February 24, 2006 Share Posted February 24, 2006 You could try calling Mustangs Unlimited and ask for Kevin or Brad. They seem to have a lot of tech expertise. 860-647-1965 or 800-243-5092 Quote Link to comment Share on other sites More sharing options...
rubin Posted February 27, 2006 Share Posted February 27, 2006 how bout windsor 351 heads outta 96 f250 into a 95 s/c mustang? just that my buddy with the stang has a 351 engine sitting around. If its worth it maybe we could pop the 351 heads on there if they flow any better Quote Link to comment Share on other sites More sharing options...
cobraz240z Posted February 27, 2006 Share Posted February 27, 2006 how bout windsor 351 heads outta 96 f250 into a 95 s/c mustang? just that my buddy with the stang has a 351 engine sitting around. If its worth it maybe we could pop the 351 heads on there if they flow any better They wont be much of inprovement if not any maybe a set of GT40P heads off a exploer they are the same 1's used on the cobra Quote Link to comment Share on other sites More sharing options...
blueovalz Posted February 27, 2006 Share Posted February 27, 2006 I know they are rare (but I believe someone is still casting them somewhere) but I used to have a "B-A" intake manifold on my 302 Mustang (the manifold was manufactured in Fort Smith, AR back in the '80s) that let me use of the 2 barrel Cleveland heads (which IMHO were much better heads for this size motor than the 4 barrel/Boss heads) on the SBF block. It required welding up/opening new water passages on the heads themselves, but it worked surprisingly well. I saw one of these intakes go on ebay a while back for close to $400. Quote Link to comment Share on other sites More sharing options...
