racerx260 Posted March 6, 2006 Share Posted March 6, 2006 I Have An 83 Turbo Motor In An Early 260.it Has The P90a Hyraulic Lifters. I Have No Budget But Lots Of Stock Parts. The Turbo Cams Have Less Lift Than The Na Cams. The 83 Cam Being The Smallist. Any Forseeable Problems Putting An Na Cam In A Solid Lifter P90 Head To Put In My Turbo?turbo Do Not Lke Overlap I Do Not Know If The Na Cam Has Any.also Can Stock Rocker Arms Be Resurfaced Or Do You Have To Use New Ones On A New Cam? Wow Me With Your Wisdom. Quote Link to comment Share on other sites More sharing options...
Clifton Posted March 6, 2006 Share Posted March 6, 2006 I run an early n/a cam on my L28T. I have also never resufraced rocker arms or used new ones and have swapped many cams. Quote Link to comment Share on other sites More sharing options...
racerx260 Posted March 7, 2006 Author Share Posted March 7, 2006 When You Order One They Tell You You Have To Get New Rocker Arms Because The Uneven Wear Will Accelerate The Wear On The New Cam.how Long Did You Ren A Cam On Old Rockers Before You Changed It? Were They Noisier? Quote Link to comment Share on other sites More sharing options...
