proxlamus© Posted March 14, 2006 Share Posted March 14, 2006 Hey guys.. I have been learning how to tune.. and been having a slight issue... at rest, under no load .. such as idle I can tune the MAP for the perfect AFR for me 13.0 AFR to be safe... and also while cruising at different points... however... under a load, such as climbing up a hill, or slowly accelerating from a dead stop such as a stop light.. I get spikes of like 20 AFR - 30AFR ... how can I tune so it stays lean at idle and cruise, but also doesn't go lean under heavy load?? Quote Link to comment Share on other sites More sharing options...
sims76 Posted March 14, 2006 Share Posted March 14, 2006 I had the same problem as you. I tried every TPSdot combo for over a year. I switched it over to MAPdot and everything is good now. Quote Link to comment Share on other sites More sharing options...
BLOZ UP Posted March 15, 2006 Share Posted March 15, 2006 with no or little load, I would get it at 14.7 at the LEAST, if not leaner. AE is very iffy, and I have had more success with MAPdot rather than the TPS based one. Also, I doubt your car would be really running well if it hit 20 or less to 1. Can you feel it jerk or does it go smooth? Do you have a wideband? Quote Link to comment Share on other sites More sharing options...
proxlamus© Posted March 15, 2006 Author Share Posted March 15, 2006 yes I am using the innovate wideband LC-1 controller and XD-1 guage Quote Link to comment Share on other sites More sharing options...
badjuju Posted May 31, 2006 Share Posted May 31, 2006 Any updates on this...? Prox? Quote Link to comment Share on other sites More sharing options...
proxlamus© Posted June 1, 2006 Author Share Posted June 1, 2006 yeh i changed my fuel VE values for a certain RPM and kPA.. it was leaning out under load.. so i fixed it now =) made the values richer Quote Link to comment Share on other sites More sharing options...
badjuju Posted June 1, 2006 Share Posted June 1, 2006 so it was just a tuning problem, not a mapdot vs tpsdot issue? Quote Link to comment Share on other sites More sharing options...
proxlamus© Posted June 1, 2006 Author Share Posted June 1, 2006 Yep... but I did also change the TPS dot a little bit.. other than that.. its great Quote Link to comment Share on other sites More sharing options...
badjuju Posted June 1, 2006 Share Posted June 1, 2006 alright duder thanks Quote Link to comment Share on other sites More sharing options...
