Patrol L28 carby
stagefumer11
Can't give you much detail but I've got a Patrol L28 sat outside from a 1987 vehicle. It's an F54 block with N42 head. Didn't have the carb on it when I collected but judging by the inlet manifold it's a single downdraft thing so pretty useless for a Z. I was also told by someone that a common mod by Patrol owners was to either swap the cam or complete head from a Z in to get a bit more power, which doesn't necessarily bode well for it having a frisky cam. Also had a points distributor, so I guess Nissan weren't fussed about decent performance!
Cheers,
Rob
Well, I don't even know what a patrol Z is but if it has an F54 block and an N42 head and flat top pistons it'll have a CR of 9.82:1 wich is a pretty good CR for a NA Z. If it has dished pistons then the CR is 8.29:1 which would be almost perfect for turbo but crappy for N/A. If you're going the N/A way put a set of 240z SU's on there and you'll have what I have, a pretty fast N/A Z. Keep in mind I have no idea what A patrol Z is ... so all of the above info may be bull $hit. good luck!
