scarp Posted August 21, 2000 Share Posted August 21, 2000 has anyone replaced there seals in the diff. If so HOW IN THE HELL do you get the half shafts out of the diff??????? Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted August 21, 2000 Share Posted August 21, 2000 Just get a screwdriver/prybar and pry the shafts/flanges out of the diff. There is a C-clip on the spline of the shaft that holds it in place. ------------------ Morgan morgan@z31.com http://carfiche.com http://z31.com Quote Link to comment Share on other sites More sharing options...
MYRON Posted August 21, 2000 Share Posted August 21, 2000 Stan, are you trying to do this process with the diff. in the car?... When I blew out my diff., they were real easy to pop out with the cover off. Like Morgan said just wedge a screwdriver behind the shaft and pry them out. I pryed on the stub axle shaft in between the axle and the shaft that holds the planetaries in place.. It came right apart... Myron Quote Link to comment Share on other sites More sharing options...
