Pump gas
JessZ
A few people recommended that I use L24 rods and Arizona Z flat tops (.040 overbore) with my N42/N42 setup. The Z calculator said this would yield a compression too high for daily driving: 14.06:1.
If this is the case then I should just stick with the L28 rods, right?
The AZC flat tops have the pin at the correct height so that they don't come over the deck. The compression will be the same as with L28 crank and rods, but the rod/stroke ratio will be better. Higher r/s ratio makes for less detonation, meaning you'll be safer running pump gas. It's been discussed a lot. Search and you'll find. Try the internet at large too.
