spring rates?
Camber plates are by far the best way to go, but another alternative is the lower control arm modified like AZ car does it. I had a shop in Roanoke Va do me up a set of factory control arms like the AZ units, just using the factory portion on the hub assembly and the Heim joint on the crossmember point and they cost me $100! I do use the camber bushings on the rear, but I'm gonna change this when I go to coil-overs...
mjk
