240Z_Master Posted April 4, 2006 Share Posted April 4, 2006 Okay, I have a Consult plug from a Z32, and I'm trying to hook it up to the RB25DET harness. I found this, but helps me a little, it seems like all nissans like to use different colors. Anyone know how to wire this bad boy up? It's only 5 wires, one for ground and one for +12V so that's the easy part. I'm having trouble with the Tx, Rx, and CLK wires. http://www.plmsdevelopments.com/images_if/consult_if_rev4.pdf Quote Link to comment Share on other sites More sharing options...
EMWHYR0HEN Posted April 4, 2006 Share Posted April 4, 2006 Well, the stock MAF consist of 4 wires. 12V, Ground, and 2 wires that are sheilded that go to the ECU. So isnt that all you have to find out, which 2 shielded wires connect to the MAF? If you have no luck here i know a guy that you can stop by and see that could probably tell you. He's in Gardena. Quote Link to comment Share on other sites More sharing options...
EMWHYR0HEN Posted April 4, 2006 Share Posted April 4, 2006 Z32 FSM or wiring diagram maybe? Quote Link to comment Share on other sites More sharing options...
240Z_Master Posted April 4, 2006 Author Share Posted April 4, 2006 Well, the stock MAF consist of 4 wires. 12V, Ground, and 2 wires that are sheilded that go to the ECU. So isnt that all you have to find out, which 2 shielded wires connect to the MAF? If you have no luck here i know a guy that you can stop by and see that could probably tell you. He's in Gardena. Uhm, this isn't for a MAF. For MAF you use this.... http://jimwolftechnology.com/wolfpdf/MAF Z32 CONVERT TO OTHER NISSANS.PDF Quote Link to comment Share on other sites More sharing options...
EMWHYR0HEN Posted April 4, 2006 Share Posted April 4, 2006 Oh, my bad. whats it for? Quote Link to comment Share on other sites More sharing options...
240Z_Master Posted April 5, 2006 Author Share Posted April 5, 2006 Oh, my bad. whats it for? For datalogging and ROM tuning (but I don't need the ROM tuning function since I have my power FC). Quote Link to comment Share on other sites More sharing options...
240Z_Master Posted April 5, 2006 Author Share Posted April 5, 2006 Found what I was looking for.... Quote Link to comment Share on other sites More sharing options...
drunkenmaster Posted April 5, 2006 Share Posted April 5, 2006 Does it work with powerFC? In the past I was told the powerFC did not output to the consult connector. Quote Link to comment Share on other sites More sharing options...
240Z_Master Posted April 6, 2006 Author Share Posted April 6, 2006 Does it work with powerFC? In the past I was told the powerFC did not output to the consult connector. You could be right, but I'm going to hook it up anyway, and recheck the pins to see in fact if the Power FC does have the pins needed. Quote Link to comment Share on other sites More sharing options...
zx300 Posted April 8, 2006 Share Posted April 8, 2006 . Quote Link to comment Share on other sites More sharing options...
zx300 Posted April 8, 2006 Share Posted April 8, 2006 hi RB 25 DET AIR FLOW METER &z32 Quote Link to comment Share on other sites More sharing options...
zx300 Posted April 8, 2006 Share Posted April 8, 2006 hi RB 25 DET AIR FLOW METER &z32 .RB 25 DET AIR FLOW METER.rar Quote Link to comment Share on other sites More sharing options...
240Z_Master Posted April 16, 2006 Author Share Posted April 16, 2006 So I got a question, on the Consult Connector, I have the four wires for the top left, but the two on the right on top, the CHX and IGN, are those needed because there is no wire out of the harness for the IGN, and the CHX doesnt have a wire coming from the harness. Quote Link to comment Share on other sites More sharing options...
